NAS542: what means synchronization
frameworker
Configuration: 1TB Raid 1 internally, 1TB external USB
If I setup synchronization instead backup to an external device, does it means that I could use this external (synchronized) volume directly inside the NAS if both of the two internal disks would be damaged?
#NAS_March
#NAS_March
Hi @frameworker
Synchronization is such as backup way let the target folder is the same as source folder, so yes, you can use the external volume while both internal disks were damaged.
But you have to know the synchronization is single way backup, the target (external disk) content would not synchronize back to internal volume, so suggest you to add/modify file into internal volume, but if you add somethiing new into internal volume, and the volume damaged before synchronization, then the data will lose.0
Hi @frameworker
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
