Does MultyX support multi-hop?
SwedBear
I got a bit confused about this as I saw a mention in a review that the Multy X uses the Star topology and not support Multi-hop yet meaning that you always get:
Node 1 - Node 2
Node 1 - Node 3
Instead of multi - hop where you can get:
Node 1 - Node 2 - Node 3
in other words, if I add a third Multy X and place it far away from the router (node 1 here) then it can connect to Node 2 with better speed instead of trying to reach Node 1.
Which of these are correct now and if multi-hop is not supported now, is that something that is being worked on? I guess multi-hop would mean some degraded performance?
#MultyX_March
Node 1 - Node 2
Node 1 - Node 3
#MultyX_March
We will release new APP and FW to support Daisy Chain around the end of this month.0
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
