How can i unhide the Multy wlan?
Zuio
since yesterday after a power outage the Multy is w-lan is only detectabel as hidden Network . What is the reason? How can i geht ist work again . The app is connecting as usual . The guest Network works normal . I can‘t find a Setting in the App to solve the Problem.
#MultyX_March
#MultyX_March
Hi @Zuio
Welcome to Zyxel Home Forum!
In order to provide you with a better assistance,
we will contact you through private message to get more information,
please check your message box.
Hi Zuio,
Thanks for your helping,let me update the conclusion in this post.
The Private Network be disabled after checking log file,this problem be resolved via enable Private Network with iOS device,For the function to enable/disable Private Network,we will add it in latest Android-App around end of this month.
- 601 USG FLEX H Series
- 480 News and Release
