Plex.TV for NAS326??
tomrc
tomrc Posts: 13 image  Freshman Member
edited October 2017 in Personal Cloud Storage
Someone know if there is any plan to implemented plex.tv on NAS326.
or someone know any  way to install plex.tv easy
#NAS_October
Best Answers
«1345
  • Fredzoul1
    Fredzoul1 Posts: 97 image  Ally Member
    edited October 2017 Answer ✓
    Hi @tomrc,
    You have possibility to install it with the 3rd party repo from Mijzelf.
    You can find more info here : http://zyxel.nas-central.org/wiki/3rd_party_zypkgs
    After you install repo, you can install package plex.
    Best Regards
  • tomrc
    Thanks, work fine. Regards
  • [Deleted User]
    [Deleted User] Posts: 1 image  Freshman Member
    can you help me with a tutorial with print screens ? or video ? i don`t now even where to start i read everything  but i fail install the repo with zy-pkgs
  • tomrc
    Dayday:
    First question you able to go the admin\zy-pkgs?
    if you response is yes
    For me the key was rename from MetaRepository_20160513_arm_013.pkg  to this "MetaRepository.zpkg" then
     webinterface execute 'Retreive list from Internet' or "Update list from Internet"
    Let me know were you feel that you are lost.
    Regards
    P.D: I try several time with the full name and sometimes w
  • channel23
    channel23 Posts: 1 image  Freshman Member
    im trying to figure out how to add plex to my nas326 please help.
  • tomrc
    Go to
    How to install
    Download MetaRepository_20160513_arm_013.pkg , rename to "MetaRepository.zpkg" , and put the text file in \\<NAS>\admin\zy-pkgs\. Then in the package menu press on the 'Retreive List From Internet' button. (On firmware 5.20+ this is the 'Cycle icon' in 'App Center->Browse->All Apps'). Only the MetaRepository package should show up. Install it, and re-request the list. You should see the (MetaRepository). If you still see only MetaRepository, disable it, enable it again, and retry.
    After the install metarepository, click  on them, install plex
  • GuyS
    GuyS Posts: 1 image  Freshman Member
    For anyone coming to this thread who has a NAS326 note that the admin folder mentioned is NOT off root of the volume e.g. /admin/ but is located under /i-data/sysvol/admin. When I put the MetaRepository.zpkg file there, the subsequent steps mentioned in the tread above worked to install the packages.
  • emau74
    emau74 Posts: 53 image  Ally Member
    Friend Collector Third Anniversary
    I can not find the directory / i-data / sysvol / admin, can you help me?
    Thank you
  • Tipcsi
    Tipcsi Posts: 2 image  Freshman Member
    edited July 2018
    I have found /i-data/sysvol/admin folder, but it does not contain "zy-pkgs" folder. If I create that manually, and copy MetaRepository.zpkg over there, and press "Retrieve List from Internet", then I still see the official packages offered by Zyxel. It does not pick up the custom pkg.
    Any idea?
    UPDATE: with SSH client I have found a "zy-pkgs" folder under /i-data/304e394d/.system/zy-pkgs. That folder seemed to be promising, because it contains the already downloaded zpkg for ZyxelCloudAgent. So I have copied the zpkg package here, pressed "Retrieve List from Internet", but the package still not showing up.
  • kimme
    kimme Posts: 38 image  Freshman Member
    First Comment Friend Collector Seventh Anniversary
    I have about the same issue as Tipcsi.
    I've added MetaRepository.zpkg to /i-data/sysvol/admin/zy-pkgs but when I try to retrieve the list it just refreshes the standard packages.
