NFS and CIFS/SMB togheter
Knugen
Are there any limitations with NAS326 that would prevent me from running a NFS-server and CIFS/SMB-share togheter on the same device?
#NAS_April
#NAS_April
AFAIK not. But you can't publish the same share on both NFS and Samba. (Using the webinterface. Using ssh it is possible)
Hi
I have nas326 too.
I am using it with apple tv 4k & infuse.
I cannot share the files in Nas with nfs system. Infuse sees the folder which I shared is empty. ( no file)
I did everything. No succeeded...
I already shared same folder via smb without any problem. I want to try and share same folder via nfs.
What should I do?
Thanks in advance.0 -
Have you installed the package of NFS from APP center?
And setup the NFS folder?
NFS folder default is hidden, and you can unhide it and access it via SMB, maybe you can share the screenshot here to see the clue.0 -
I already shared video folder via smb without any issue.And still connected. Infuse uses it.
But, the people say "nfs is quicker than smb". So ı wanted to try and see it.
You will see the pictures below. I installed nfs application and setup it to share "video" folder. But
Infuse saw it "no files - in it" everytime.
Please check photos.
creating nfs folder?
The NFS folder is under /i-data/f3606bb1/nfs/, but the default video folder is under /i-data/f3606bb1, so if you put the file under /i-data/f3606bb1/video, and through NFS, then you cannot see the file, they is why you see empty.
Would you please say me the clearly, "what should ı do exactly than" ?
If possible step by step
Let me explain more, since the nfs folder was created under /i-data/f3606bb1/, but didn't display on your shard folder list, so you need to create a share folder and name "nfs" on your screenshot 2, then it might be possible to link to your NFS folder, and you can see the video under nfs folder.
And it would be more easier to upload/download file to your nfs folder via CIFS/SMB, and share to Apple tv via NFS1 -
I did anotder folder to share named nfs and did nfs share again. Am i wright?
In theory, nfs folder which ı created 2 minutes a go is totaly empty by the way.
Should ı copy all my movies inside the "video" folder to nfs folder again to able to find by the apple tv 4k player?
- 588 USG FLEX H Series
- 476 News and Release
