LTE Router with Bridge mode
flems
flems Posts: 3 image  Freshman Member
edited January 2024 in Mobile Broadband
Hi
I need a 4G LTE modem. It will need to support Bridge mode, as I will continue to use existing Router and accesspoint.
I am looking 3 these 3 options:
LTE3301-M209.
- Pro: Pricepoint, Bridge mode mentioned in datasheet
- Con: Only 100mbit Ethernet, 150mbit max LTE
LTE4506-M606:
- Pro. Pricepoint.
1gbit Ethernet, 300 mbit max LTE
- Con. Bridge mode not mentioned anywhere, except for in user guide.
LTE7460-M608
- Pro.
1gbit Ethernet, 300 mbit max LTE, Bridge mode mentioned in datasheet
- Con: Hefty pricepoint.
My main question is really if there is any difference in the Bridge support between the 3? I lean towards 4506-M606, but are concerned about the lack of Bridge support mentioned on the product pages
#LTE_April
