LTE Router with Bridge mode
I need a 4G LTE modem. It will need to support Bridge mode, as I will continue to use existing Router and accesspoint.
I am looking 3 these 3 options:
LTE3301-M209.
- Pro: Pricepoint, Bridge mode mentioned in datasheet
- Con: Only 100mbit Ethernet, 150mbit max LTE
LTE4506-M606:
- Pro. Pricepoint. 1gbit Ethernet, 300 mbit max LTE
- Con. Bridge mode not mentioned anywhere, except for in user guide.
LTE7460-M608
- Pro. 1gbit Ethernet, 300 mbit max LTE, Bridge mode mentioned in datasheet
- Con: Hefty pricepoint.
My main question is really if there is any difference in the Bridge support between the 3? I lean towards 4506-M606, but are concerned about the lack of Bridge support mentioned on the product pages
#LTE_April
Hi Flems,
For example, if your location is suburban, I suppose LTE 7460 will be better choice. You can refer to applications/specifications of these devices on website and then choose the one is good for you.
https://www.zyxel.com/tw/zh/products_services/LTE-Indoor-Router-LTE3300-Series/
https://www.zyxel.com/tw/zh/products_services/4G-LTE-A-Outdoor-Router-LTE7460-M608/
https://www.zyxel.com/uk/en/products_services/4G-LTE-A-HomeSpot-Router-LTE4506-M606/
All of three devices are support bridge mode. But I think you need check your environment/location etc first and then select which one is better for you.
Hi Yekku. Thanks for the response. What should I check in the environment?0
Hi Flems,
Thanks Yekku. I hae pretty good signal also indoors, so that is not a concern. Thanks for the advice.0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 420 News and Release
- 89 Security Highlight
