NAS540 backup using rsync?
tsalmi123
Has anyone managed to use this feature successfully? I am trying to initiate a rsync backup job to a remote linux system but I keep getting "connection broken in socket" errors when clicking on "show target content".
Does all traffic go through SSH or is port 873 also used? Either way, it doesn't work for me.
Any help appreciated!
#NAS_May
#NAS_May
The box doesn't have rsync. The 'Backup Planer' package contains a copy of zysync, which is a (non-compatible) derivative of rsync, which uses the same port.
If you want rsync, you'll have to use a 3th party package like Entware-ng or RandomTools
And don't forget to disable/uninstall Backup Planer, because it will keep the rsync port occupied.
That weird, to say at least. Why do they literally offer it to us as rsync in backup planner? Go figure. I'll give the 3rd party tools a try. Thanks!
Why do they literally offer it to us as rsync in backup planner?Really? Didn't see that before. Maybe my information is outdated by now. The firmware rsync clone used to be incompatible, but maybe that is cured in the latest update.
On the other hand, it still doesn't work for you.
Maybe they added this feature in a more recent firmware upgrade. Or tried at least
I opened a support ticket, so let's see what Zyxel has to say about it. I'll keep you posted! 0 -
I'm still in discussion with support. However, a couple things have been confirmed so far.
- It is rsync compatible (version 3.0.9 and protocol version 30)
- rsync needs to run in daemon mode listening to TCP port 873
- 588 USG FLEX H Series
- 477 News and Release
