instable /blocked internet connection with Multy X
Zuio
1. we often experience loss of connection . to cure it i have to go offline with the Ipad, macbook or even android mobile, and reconnect. it also helps to change the network 2.4MHz to 5 MHz or reverse.
2. we turn off our hotspots at night. the slave hotspot with a timer. if i am surfing connected on the main hotspot i have also to reconnect or change frequency.
I have installed the latest firmware only a view days ago but still the same.
regards
#MultyX_May
regards
#MultyX_May
I also have a similar problem. Does your problem the same as below picture?
"It also helps to change the network 2.4 MHz to 5 MHz or reverse." -> How to help?
May I know what's your meaning about second point? How many Multy X units you have?0 -
We have two Multy x.
About your picture, until now i haven‘t seen something similar.
Some how i think it has to do with the Connection ID witch expires, an needs to be Updates or so.
In order to provide you with a better assistance, we have contacted you via private message. Please kindly check your message box.0
- 588 USG FLEX H Series
- 477 News and Release
