Admin password reset after update NAS 542 to firmware 5.21
noway
Hy folks, maybe I am not the only one with the following problem:
I updated today to firmware 5.21 on automatic request on login as a user to the NAS 542. After updating the admin login has been reset. Procedure is known, so I logged in with default password and was asked to change that. After input of the new password it was impossible to activate the change and I was rejected after 60 sec elapsed.
Has somebody had this problem (since 5.21) has June 2017 as a release date?
Can somebody give me a hint how to acces the admin role?
#NAS_May
#NAS_May
Hi, do you use any special word as password? Non-ASCII code? For example: special German word: "Ü"
here is ASCII information: https://en.wikipedia.org/wiki/ASCII
if the password you still can't use to access NAS GUI, try reset your password by pressing HW reset button with 1 beep and release, then the password will change back to default "1234"0
if the password you still can't use to access NAS GUI, try reset your password by pressing HW reset button with 1 beep and release, then the password will change back to default "1234"0 -
I have the same problem. After Reset the admin password is default and I can't change it. Not even to a simple password (if I use illegal keys it won't accept, but the simple password is accepted, but the admin password keeps on being default).
Any suggestions?0
- 588 USG FLEX H Series
- 477 News and Release
