Can you connect directly to laptop.
kneehigh
I'm in a situation that I need to be offline for a little while. Is it possible to directly connect the NAS326 to my MacBook?
#NAS_May
#NAS_May
Have you tried the manual? Reading over mine I Remember a bit of info in there.
-Hoot0 -
You mean like this: MACBOOK ---- LAN ---- NAS326 without router?
If yes, try setup the statis IP address on your NAS and PC with same subnet, such as 192.168.1.33 and 192.168.1.34, then you are able to access NAS data directly.
- 3K Nebula
- 223 Nebula Ideas
- 6.6K Security
- 628 USG FLEX H Series
- 353 Security Ideas
- 85 Switch Ideas
- 54 Wireless Ideas
- 299 Service & License
- 492 News and Release
- 108 Security Highlight
