Can you connect directly to laptop.
kneehigh
kneehigh Posts: 1 image  Freshman Member
edited May 2018 in Personal Cloud Storage
I'm in a situation that I need to be offline for a little while.  Is it possible to directly connect the NAS326 to my MacBook?
#NAS_May
  • Hootinannie
    Hootinannie Posts: 2 image  Freshman Member
    Have you tried the manual? Reading over mine I Remember a bit of info in there.
    -Hoot
  • Ijnrsi
    Ijnrsi Posts: 254 image  Master Member
    You mean like this: MACBOOK ---- LAN ---- NAS326 without router?
    If yes, try setup the statis IP address on your NAS and PC with same subnet, such as 192.168.1.33 and 192.168.1.34, then you are able to access NAS data directly.
