Multy X - Daisy chain config
DaveT
DaveT Posts: 5 image  Freshman Member
edited June 2018 in Multy WiFi System
I understood Multy X didn’t operate as a true mesh network – it used a star configuration in which all nodes talked directly to the router. An update was promised in March that would add support for daisy-chained configurations, has this happened with the new v2 firmware?  I’m considering buying a 3 piece system.
#MultyX_June
  • ENDLESS
    ENDLESS Posts: 56 image  Ally Member
    Hi odifoke,
    You can check WiFi Backhaul to know which nodes are connected each other.
    1. Open Multy APP
    2. Tap the extender icon on home page
    3. Tap WiFi Backhaul
    4. Multy APP will display connect node
  • Zyxel_Steven
    Zyxel_Steven Posts: 246 image  Zyxel Employee
    edited June 2018
    V2.00 firmware and APP has already been supported Daisy Chain. :)
  • odifoke
    odifoke Posts: 29 image  Freshman Member
    is there a way to check if you are routing via 2 nodes vs star?
  • ENDLESS
    Hi odifoke,
    1. Open Multy APP
  • woo_j
    woo_j Posts: 2 image  Freshman Member
    Hi, here its said , multy U is daisy chain available, but not option in the app, and it said not in the manual ... I'm disappointed I bought 4 multy U for this ...
