LTE7460 lan speed?
Second question is how do connect to LTE7460 if i put it in a bridge mode?
#LTE_June
Hi ariman,
To answer your questions as followings. I hope it can help you.
1. It's 1 GigE port
2. You can refer to user guide page 60 to configure it to bridge mode.
ftp://ftp2.zyxel.com/LTE7460-M608/user_guide/LTE7460-M608_V1.00.pdf
LAN speed is still 380Mb from computer to computer?0
Hi ariman,
what is "computer to computer" you mean? Can you please describe more detail of your scenario/topology?0 -
Read my first post? Gb switch behind 7460 and 2 computers, file transfer speed max 400Mb from computer to computer. Why so low? Tried other Gb switch also, same results. Is 7460 DHCP server so slow?0
Hi airman,
I test the LTE7460’s LAN performance locally. I connect a switch (Zyxel GS1900-8) to the LTE7460’s LAN; 2 PCs are connected to the switch. After a 30-minute test, the average throughput between 2 PCs is 928 Mbps.
I would like to clarify whether the LTE7460 is the root cause. In order to simplify the problem, could you please set static IP address on those 2 PCs, remove the LTE7460 and keep those 2 PCs connected to the switch and test the throughput again?
If the issue still happens, could you please check your switch or your PC’s LAN setting, especially the “Speed and Duplex”?
It is suggested to set the duplex mode of both PCs and the corresponding switch ports to “Auto”.
Testet speed with Cisco RV130W router. I replaced GB switch with Cisco router making own subnet and i got 980Mb file transfer speed. I dont see any other possible fail than Zyxel?0
Hi airman,
Can I double confirm your scenario first? Is it same as below one?
“Cisco router ----- PC_1, PC_2”.
If your scenario is same as above, I think we cannot make sure if the issue is related to LTE7460 currently. This is because it’s only can confirmed the settings of duplex mode on both PCs are no problem.
Can you please help to try to remove LTE7460 to check again? To keep switch and both PCs, like “Switch ----- PC_1, PC_2”. We would like to clarify if it’s related to switch or not.
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
