SMB1 disabled in Windows 10
BDWHITE
SMB1 is now disabled by default in Windows 10, as it is considered to be a security risk. That means that I can no longer see my NSA 3120S from my desktop, even though it has the latest firmware. Does anyone know a solution to this problem?
#NAS_June
You can either enable SMB1 in Windows or install SMB2 on your NAS, or stop using SMB, and use FTP instead.0
Dear Mijzelf, thanks very much for the advice.0
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
