Multy X - Daisy chain config
DaveT
I understood Multy X didn’t operate as a true mesh network – it used a star configuration in which all nodes talked directly to the router. An update was promised in March that would add support for daisy-chained configurations, has this happened with the new v2 firmware? I’m considering buying a 3 piece system.
#MultyX_June
#MultyX_June
Hi odifoke,You can check WiFi Backhaul to know which nodes are connected each other.1. Open Multy APP2. Tap the extender icon on home page3. Tap WiFi Backhaul4. Multy APP will display connect node
V2.00 firmware and APP has already been supported Daisy Chain.
is there a way to check if you are routing via 2 nodes vs star?0
Hi, here its said , multy U is daisy chain available, but not option in the app, and it said not in the manual ... I'm disappointed I bought 4 multy U for this ...0
- 588 USG FLEX H Series
- 477 News and Release
