WAH7608 External TS9 Antennas
kirbey
I buy a LTE router Zyxel WAH7608 today.
On the box, TS9 antennas support declared as it:
However, no sign about this property. It have two openable notch cover on the upper side. When I open these, small ports like anrenna socket are available. But these are can not opened fully. I cant find a way to connect TS9 antennas.
How can I connect it or it is just a text on the box? Thanks.
#LTE_Aug
#LTE_Aug
Hi kirbey,
Thanks for you to choose our WAN7608.
The picture you provided is correct side to connect TS9 antennas. You can refer to my connection as followings.
- 588 USG FLEX H Series
- 477 News and Release
