NAS326 - Backup method "synchronize" and automatic backup clean-up?
DReffects
DReffects Posts: 1 image  Freshman Member
edited August 2018 in Personal Cloud Storage
Hi there,
so i have a USB disk connected to a NAS326 and am using the "publizieren" -> "synchronize" backup method to backup to USB.
I am just wondering: will the mechanism automatically clean up older files during the backup or will the external drive eventually run full?
If so, what backup method will provide a fully automated clean up? The archive method is not useable since it takes forever and my data storage varies too much to even use it properly.
#NAS_Aug
  • Ijnrsi
    Ijnrsi Posts: 254 image  Master Member
    Throuhg its description, publish will copy source files to the destination and keep any additional files, so it will old files till it is full, but the same file is updated in source folder, then it will overwite the destination one.
    For clear up part, the backup methmod of synchronization -> Mirror and Rsync is what you required, they will delete all files in target side before running backup, but it will take time to finish all copies.
