NSA325v2 does not boot after FW update
I know others ran into same issue that after FW update the NAS is not accessible anymore.
Nearly found issue as in some boot issue, but the required files are not downloadable anymore. Can anyone help me in the correct files in solving this issue?
Bit more background: system led is blinking continuously, Twonky works so DHCP/IP works, NSU does not show NSA and connecting to drives is not possible anymore.
Did all sorts of resets like described elsewhere, including online version, even removed disks and boot. Prepared a FAT32 USB with 481AALS1C0.bin on it, but lack folder/name details. Ordered serial cables already, just in case (read some articles).
It looks similar as <https://homeforum.zyxel.com/discussion/444/nsa325v2-not-working-after-firmware-upgrade#latest> but resetting does not work.
#NAS_Sep
As I rethought my question it does not make sense. Having IP connectivity means no boot issue, but some config mistake. Decided to do another full system reset and this time it continued, making the NAS visible again. Sometimes you need to rethink stuff by writing things down...
- 588 USG FLEX H Series
- 476 News and Release
