3rd party repositories has been closed?
So, is it possible to tun Entware on NSA310 (fw4.7) if I install proper libc library? Or somenthing else?Yes Entware-ng can run on a NSA310, provided you exchange libc by a patched one. Unfortunately that's not just any libc.
I would be very grateful if you could provide me those files.
I couldn't find a backup of my patched libraries.
@waiting4 and @MGD, Entware-ng will run fine on a 326, but it's not a step-up to Plex. Plex is not available as package for Entware-ng (nor for FFP). The way to install Plex is to download a package for the Synology, extract that, put it in the right directories, create some environment variables and start the binary. @barmaley2 has researched this, and I have put his findings in both an FFP package and a zypkg package, but in both cases it's basically a script, and you'll have to provide the compatible Plex package.
If nas-central.org is back, both scripts are available.
For the NSA310 there is a complicating factor. Plex dropped support for Armv5 a few years ago, and I don't know if there are still Armv5 packages for download, nor if they are still compatible with clients.I think NAS326 processor (1300MHz) is to weak for Plex, as in mine NSA310 1200MHz.AFAIK a NAS326 is powerful enough to run Plex, although I don't have experience. It won't transcode, but it won't transcode on any Arm NAS.
1300MHz Armv7 is not really comparable to 1200MHz Armv5.
I wouldn't complain at all if forum nas-central.org and zyxel.nas-central.org downloads was still avaiable, but in current situation... It sucks.
OK all clear. I thank both and I hope nas-central will be back online soon.
- 588 USG FLEX H Series
- 477 News and Release
