rnsapshot on NAS540 v5.21
scorcher6
I have been using rsnapshot on my NAS540 for a while until updating the firmware to 5.21.
Tweaks seems to be working after the update, but services like rsnapshot and ssmtp does not.
Also, I'm not sure entware is working.
Previously it ran from /opt/bin/rsnapshot, but now the rsnapshot file is located under
/i-data/ba809db3/optware/etc.
Does anyone now what happened and how to fix it?
#NAS_Sep
#NAS_Sep
id you upgrade from <5.10? In that case it's the old "optware" (including quotes) which was running on your box. Unfortunately that is not compatible with fw5.10+. In that case I'm a bit surprised that 'Tweaks' seem to work. On fw 5.0x that was an "optware" package. But I must admit that I have forgotten the details.
You can install Entware-ng instead. Normally you could do that using MetaRepository, but nas-central.org is down for the moment.
Instead you can use 'the stick'. I'll PM a download link.
I'm pretty sure I upgraded from firmware 5.11, but I'm not sure.
The reason I thought tweaks was still working was because the "change homedir" tweak is still working.
Thank you for the link. I have finally had physical access to the NAS. I placed the content of the zipfile on the USB stick and restarted the NAS. The content of the USB changed as I think it's supposed to do, but i'm not sure anything else happened. There are few instructions in the readme and I can't find much online either. Should I be able to run opkg commands now?
Btw, I removed the old entware through the GUI before mounting the stick. Only tweaks and MetaRepository apps can be seen in the GUI.0 -
Basically yes. If you have a populated /opt/. If not, look on the stick for a logfile, to see what went wrong.
There is one problem, due to a missing package from nas-central /opt/sbin and /opt/bin are not included in the path. So to run opkg you have to provide the full path, /opt/bin/opkg
Btw, I removed the old entware through the GUI before mounting the stick. Only tweaks and MetaRepository apps can be seen in the GUI.Right. In that case you didn't upgrade from <5.10. There never was a MetaRepository for <5.10, as you can see in the release notes of MR:
20150916zypkg011:- Added support for the NAS500 series, firmware 5.10 and newer
- 588 USG FLEX H Series
- 477 News and Release
