copy modified apcupsd conf at startup
nasigormk
nasigormk Posts: 1 image  Freshman Member
edited October 2018 in Personal Cloud Storage
hi MIjself
My unit is NAS326 it has  FFP and ENTware works without problem
i want to make the script which copy ethernet apc network configuration from
cp /opt/etc/apcupsd/apcupsd.conf and put it on original /etc/apcupsd/ folder restart and works ,i need this because original firmware has been locked this feature .
i made executable .sh code but dont know where to put it
So the unit can shutdown without  tweaks tools use network from the card APC 9617
I have no idea how  thanks for the help
Regards
Igor
#NAS_Oct_2018
  • Mijzelf
    Mijzelf Posts: 3,038 image  Guru Member
    /opt/etc/init.d/, then it will be executed on start of Entware-ng. It is possible that you'll have to send a HUP signal, or restart apcupsd, as I don't know if it's already running by then.
