Mount external USB drive on NSA310
PaulF
Hi, I have a USB portable hard drive with an NTFS and ext4 partitions. I'd like to use the ext4 partition for backup of my NSA310, using rsync. The NTFS parition is visible/mounted, but I can't get the ext4 partition mount. I'd appreciate any advice/pointers on how to do this.
The NTFS partition is sdb1 (label verb_ntfs), ext4 is sdb2 (label verb_ext4) and sda is the internal drive of the NSA310. Output of various commands below. Tried to attach it to a new directory in /mnt...
Thanks in advance/Paul
admin@nsa310:~$ cat /proc/partitions
major minor #blocks name
7 0 139264 loop0
31 0 1024 mtdblock0
8 0 976762584 sda
8 1 514048 sda1
8 2 976245952 sda2
31 1 512 mtdblock1
9 0 976244928 md0
8 16 1709326582 sdb
8 17 1228800000 sdb1
8 18 480525312 sdb2
admin@nsa310:~$ sudo blkid
/dev/loop0: UUID="73858854-5baf-48c8-ae04-a898b8f904a7" TYPE="ext2"
/dev/sda1: UUID="8bf2f209-a76f-4cc8-af15-4b6325b3e953" TYPE="ext2"
/dev/md0: UUID="30327c42-7472-4281-950b-6f2f5ed5f045" TYPE="ext4"
/dev/sdb1: UUID="68DC8228485FAD77" TYPE="ntfs" LABEL="verb_ntfs"
/dev/sdb2: UUID="d510ecd2-52b1-424b-9ae1-c830248fd99e" TYPE="ext4" LABEL="verb_ext4"
admin@nsa310:~$ sudo fdisk -l
Disk /dev/sda: 1000.2 GB, 1000204886016 bytes
255 heads, 63 sectors/track, 121601 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Disk identifier: 0x6f6d65c9
Device Boot Start End Blocks Id System
/dev/sda1 1 64 514048+ 8 AIX
/dev/sda2 65 121601 976245952+ 20 Unknown
Disk /dev/sdb: 1750.3 GB, 1750350419968 bytes
255 heads, 63 sectors/track, 212801 cylinders
Disk identifier: 0x1bd0feb2
/dev/sdb1 1 152979 1228800000 7 HPFS/NTFS
/dev/sdb2 152979 212802 480525312 83 Linux
admin@nsa310:~$ mkdir -p /mnt/mountpoint
admin@nsa310:~$ sudo mount -o ro /dev/sdb2 /mnt/mountpoint
Password:
mount: wrong fs type, bad option, bad superblock on /dev/sdb2,
missing codepage or helper program, or other error
In some cases useful info is found in syslog - try
dmesg | tail or so
admin@nsa310:/mnt/mountpoint$ mount
/dev/sdb1 on /e-data/6e998211b7d9934b7193c867ea922892 type tntfs (rw,relatime,uid=99,gid=0,umask=00,nls=utf8,case_sensitive,nocache,errors=continue,mft_zone_multiplier=1)
#NAS_Oct_2018
7 0 139264 loop0
31 0 1024 mtdblock0
8 0 976762584 sda
8 1 514048 sda1
8 2 976245952 sda2
31 1 512 mtdblock1
9 0 976244928 md0
8 16 1709326582 sdb
8 18 480525312 sdb2
Password:
dmesg | tail or so
#NAS_Oct_2018
Here is your problem:
JBD: Unrecognised features on journal
Your ext4 filesystem is 'too new'. Maybe you can mount it if you disable the journal on another linux box. (And maybe re-enable it from the NAS)The command to disable it is<pre class="CodeBlock"><code>tune2fs -O ^has_journal /dev/whateverAnd I *think* you can re-enable it using<pre class="CodeBlock"><code>tune2fs -O has_journal /dev/whateverBut I don't know if the tune2fs on the NAS can do that.
I wouldn't be surprised if that old box doesn't support ext4. You can check that with
<div>cat /proc/filesystems</div>
Thanks, Mijzelf. From the output of the command you suggested, I think ext4 is supported:
admin@nsa310:~$ cat /proc/filesystems<br>nodev sysfs<br><snip><br>nodev devpts<br> reiserfs<br> ext3<br> ext2<br> ext4
Thnaks/Paul
OK. The error mount (actually busybox) spawns is a catch all. It just says 'failed'. Further it will try all filesystems, until one fits, cluttering the logs.So try
<div>mount -t ext4 -o ro /dev/sdb2 /mnt/mountpoint</div><div><br></div><div>dmesg | tail<br></div>
to see what is going wrong.BTW, where did you get sudo from?1 -
Thanks again for sticking with this, Mijzelf.
admin@nsa310:/$ dmesg | tail<br>tntfs error (device sdb2, pid 3025): read_ntfs_boot_sector(): Mount option errors=recover not used. Aborting without trying to recover.<br>tntfs error (device sdb2, pid 3025): ntfs_fill_super(): Not an NTFS volume.<br>uncorrectable error : <br>end_request: I/O error, dev mtdblock7, sector 20352<br>Buffer I/O error on device mtdblock7, logical block 2544<br>end_request: I/O error, dev mtdblock7, sector 20352<br>Buffer I/O error on device mtdblock7, logical block 2544<br>EXT4-fs (sdb2): barriers enabled<br>JBD: Unrecognised features on journal<br>EXT4-fs (sdb2): error loading journal
Regarding sudo - I installed a package of utilities, which added a number of useful commands & functions (including rsync) that I found on the old NAS central forum - I think this may even have originated from you (?) - suspect that this may also have added sudo.Thanks/paul
Thanks very much, Mijzelf - I'm trying it out now - bit of finger trouble turning the journal off, but will keep trying.0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
