NAS326 unable copy/move/delete folder or file after last firmware update
  • UmaPlay
    UmaPlay Posts: 1 image  Freshman Member
    First:excuse my English, I'm german :)
    I've had exact same Problem with my NAS326. After trying everything I just moved back to AAZF.1
    download the Firmware (AAZF.1)
    Login as root to your NAS via putty or other Terminal Programm and type in this (or copy)
    echo 1 >/firmware/mnt/info/revision
    after that you can go back to AAZF.1, just do it like normal, like upgrading Firmware.
    Hope this helps, for me, my Filebrowser is working again :)
  • pinoytech
    pinoytech Posts: 1 image  Freshman Member
    anyone manage to fix this issue?
  • Mattius
    Mattius Posts: 8 image  Freshman Member
    I'm astounded that Zyxel have not bought out a hotfix for this. My guess is that they have made a real Boo Boo & don't know how to fix this problem!!!! :s
  • Mattius
    PLEASE ZYXEL HELP!!!!!!!!!!!!!!!!!!!
  • Asturel
    Asturel Posts: 3 image  Freshman Member
    I'm trying and I get this error: sh: can't create
    sh: can't create /firmware/mnt/info/revision: Permission denied
  • Mijzelf
    Mijzelf Posts: 3,038 image  Guru Member
    Login as root (using your admin password)
  • Asturel
    @Mijzelf can you please explain it step by step (line by line  :) )
  • Mattius
    I've send two Emails to Zyxel & not had any response. Are the company on the verge of insolvency? 3 months with this problem & no fix. Something is NOT right at Zyxel!! :'(
  • Mijzelf
    @Asturel : You used PuTTY or another ssh client to login at the NAS, using your admin account. You should login using the username 'root' (which has the same password as admin). On Unix systems root is the user having all rights. So this solves your 'Permission denied'.
  • Asturel
    @Mijzelf, oh my God! Thanks a lot It's working again! You are awesome
