Enware does not work
olsamurai
Hi! After the nas-central-portal is offline, entware-ng does not work (update, upgrade, install, etc.). MetaRepository I have switched according to the instructions from Mijzelf on zyxel.diststation.eu. Entware-ng is installed on my NSA-325v1 and NAS-540 as a usb-stick. Is it possible to customize or reinstall entware? Thanks in advance!
#NAS_Oct_2018
#NAS_Oct_2018
Best Answers
If you want to customize, you'll have to edit the repo file, in /etc/opkg/, when I'm not mistaken. Reinstall should just work, at least for the zypkg. I'm not sure about the stick.
Yes, /opt/etc/opkg.conf, and exchange 'downloads.zyxel.nas-central.org' by 'zyxel.diskstation.eu'
Many Thanks, Mijzelf! Do you mean /opt/etc/opkg.conf? What repository could I enter instead of nas-central (zyxel.diskstation.eu\Users\Mijzelf\zypkg-repo\test\Entware-ng\binaries\armv7\Packages)?
- 3K Nebula
- 229 Nebula Ideas
- 130 Nebula Status and Incidents
- 6.6K Security
- 661 USG FLEX H Series
- 359 Security Ideas
- 86 Switch Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 305 Service & License
- 496 News and Release
- 95 Security Advisories
- 5K FAQ
- 89 About Community
- 110 Security Highlight
