NAS326 unable copy/move/delete folder or file after last firmware update
Hi,First:excuse my English, I'm german
I've had exact same Problem with my NAS326. After trying everything I just moved back to AAZF.1download the Firmware (AAZF.1)Login as root to your NAS via putty or other Terminal Programm and type in this (or copy)echo 1 >/firmware/mnt/info/revision
after that you can go back to AAZF.1, just do it like normal, like upgrading Firmware.Hope this helps, for me, my Filebrowser is working again
I'm astounded that Zyxel have not bought out a hotfix for this. My guess is that they have made a real Boo Boo & don't know how to fix this problem!!!!
PLEASE ZYXEL HELP!!!!!!!!!!!!!!!!!!!
I'm trying and I get this error: sh: can't create
sh: can't create /firmware/mnt/info/revision: Permission denied0 -
Login as root (using your admin password)
I've send two Emails to Zyxel & not had any response. Are the company on the verge of insolvency? 3 months with this problem & no fix. Something is NOT right at Zyxel!! :'(0
@Asturel : You used PuTTY or another ssh client to login at the NAS, using your admin account. You should login using the username 'root' (which has the same password as admin). On Unix systems root is the user having all rights. So this solves your 'Permission denied'.
2
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
