NAS326 unable copy/move/delete folder or file after last firmware update
Still heard absolutely nothing from Zyxel. I think perhaps their days are numbered?
I guess this is what happens when you buy a low cost product compared to a quality one like QNAP or Synology.
I think, the zyxel company will close very soon. This situation & progress is not normal.0
Is there anything other than selecting Desktop in the NAS Starter Utility to move/copy/del files. My permissions are a bit wrong in some Dirs on the NAS which means on these particular dirs I can only copy/move/delete using Desktop in NAS Starter Utility rather than via windows on the affected dirs. Well, I can't know because latest f/w stuffed it up! H E L P ! (Please).0
Please stick this post to the top of the forum.
Nobody at Zyxel seems remotely interested?????????
Zyxel , say something, anything.
It is enough.
What kind of company you are?
It is really unbelievable !!!
same problem for me, can't delete or move file... when i try to login with putty error: Network error: connection refused. Someone can help me? i need to downgrade the firmware to fixit plz0
Is there anyone to hear us ?0
For Nas 326 there will be a firmware update
available. This will solve this problem. Should be seen in the dashboard Settings>System>FW Upgrade.V5.21(AAZF.3)
- 439 Beta Program
- 529 USG FLEX H Series
- 330 Security Ideas
- 49 Wireless Ideas
- 290 Service & License
- 4.6K FAQ
