NSA325v2 doesn't work
Saani
Posts: 10 Freshman Member
Hi all,
is there any way to reinstall a firmware with USB-Stick (or other way)? My NSA325 v2 is starting, power LED and USB led are on but that is all. I have no connection to NAS, my Router does not see him, i also had try to start without HDDs. There is also no beeping at hard reset. All cables are checked and ok. I got it as a gift from a friend and do not know a history of NAS. Thank you
#NAS_Nov_2018
#NAS_Nov_2018
Does the network led next to the network port light when you plugin a network cable (connected on the other side)?
Yes, it is connected on the other side on my router, two led are light, upper one in orange, lower one in yellow. Sometimes they are flashing very fast for about 4-5 times.
I also have read something about "force" installing stock firmware from USB stick, but i didn't find a files for usb stick.0
Sounds good.Yes, nas-central.org is down for several months now. I had an 'upgrade key' for the NSA325v2 there.It seems I still have a backup. The size is the same as the one listed (but not stored) in archive.org. I'll pm you a download link.1
Hey thx a lot for your help. Unfortunately i tryed it with different 3 USB sticks, both with FAT and/or FAT32, but NAS shows no reaction after power ON.
1. Copied files from folder nsa310_fw to root of USB stick
2. Replaced Upgrade_C0 file with nsa310_check_file_C0, rename to Upgrade_C0
3. Inserted USB stick to back USB port of NAS, power on NAS, press ON button on the NAS
I am right with this steps?
thx0 -
No. The back USB port and FAT32 is correct, but you should extract the zipfile as-is to the USB stick. So the stick should contain a subdirectory nsa310_fw.
Nothing happens. Should i also push power on button or just plug in ac adapter?
Edit: of course.0 -
Do you have an USB stick with led? Can you see if it's accessed on boot?
Hi, all 3 stick have led. The led is going on and flashing, but 10-12 secs. after starting NAS, flashing twice for 4-5 times then led goes off.
EDIT: flash on another stick has continuous light, but nothing happens0 -
Now i know the history of NAS. My friend tried to install Debian, 1 year ago, with USB stick, something went wrong, since then only the lamps and fan are going on, otherwise he gives no a sign of life. Can i recover this? I have got the NAS without HDDs, i only have one 500gb 2.5 at home.
- 398 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 83 Nebula Status and Incidents
- 5.2K Security
- 99 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 923 WirelessLAN
- 35 WLAN Ideas
- 5.9K Consumer Product
- 212 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2.1K FAQ
- 1K Nebula FAQ
- 445 Security FAQ
- 238 Switch FAQ
- 213 WirelessLAN FAQ
- 47 Consumer Product FAQ
- 142 Service & License FAQ
- 72 About Community
- 62 Security Highlight
