NSA325 with Windows 10
Also, the NAS Starter Utility installs but does not run correctly on Windows 10.
I therefore have two questions:
1. Is the NSA325 in some way incompatible with Windows 10? It clearly works up to a point, but is there something fundamental about the file system that makes it work only partially?
2. Is there a version of installable software for Windows 10 that reliably enables a connection to the NAS for the purpose of administration?
#NAS_October
Incidentally, before anyone asks, firmware is at latest version: NSA325_4.81(AAAJ.1)0
Hi @iainmackay,Have you done something on your NSA325 or Windows 10?It should work normal between NSA325 and Windows 10, so if you doesn't know what happen on NSA325, that you can try to reset it and check the problem solved or not.Also, I check the NSU tool from zyxel website, but no information regards Windows 10 supported, so NSU can't work normally with Windows 10.As I know, there is a website to help user to find the local NAS as http://findme.zyxel.com, maybe you can try it.Then you can set a static IP to NSA325 and save it as the bookmark.0
Second possibility
You can find the mac adress on the rear of your nas (or under). With this, connect on the web-interface of your routeur, find in the dhcp table what ip your NAS325 receive and use this to connect in the GUI of the nas. You can after fix the IP in the routeur with mac reservation or in your NAS325 with GUI on the network parameter.0 -
I have had the same problem. I have a N325v2. I have spent a long time trying to fix the problem. The problem is that a new windows 10 update change from SMBv1 to SMBv2. I have disabled SMBv1 and still can't locate the NSA325v2 from any of my computers on windows 10. I am upset that ZXXEL have not release a new update so that it is computable with SMBv2. You would have thought that ZYXEL would support their customers. I have read that they are not going to release a up date for NSA325V2 and other older versions. So not I can't use it on any windows 10 computer unless I buy a new Server, so how do I update and keep my hard disc with all the date on top a new system with out losing any information. Can anyone help. I have found the following link
Any help from anyone would be most appreciated, Thank you.
It's possible to install SMB2 support using Entware-ng .When Entware-ng is installed, install the zyxel-samba-replacement package.1
BTW, that's version 20181002zypkg006
Please assist. I installed a NAS326 last weekend, and right out of the box, encountered similar problems i.e., the startup utility doesn't load using Windows 10. I tried the link noted above, and it is closed. Just FYI, I've upgraded using v5.21(AA2F) firmware.0
- 397 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 5.1K Security
- 87 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 917 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 211 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2K FAQ
- 916 Nebula FAQ
- 422 Security FAQ
- 237 Switch FAQ
- 207 WirelessLAN FAQ
- 47 Consumer Product FAQ
- 139 Service & License FAQ
- 72 About Community
- 62 Security Highlight
