NAS542 reboot continuosly after power fail
Pandino84
Posts: 14 Freshman Member
power fail in my house... now my zyxel nas542 reboot itself continuosly.... any ideas? help please...
#NAS_Dec_2018
#NAS_Dec_2018
reset and deep reset non solve...
maybe's i have to recharge the firmware? but how?
Continuously? Which frequence?
power on, control disk, continuos blink the first led, shutoff. total operation about 1 minute.
One minute. In that case it's not the bootloader which reboots the box, which is good. That's about the time it needs to get to the desktop.Does it also reboot if you pull the disks? Did you have timed shutdown enabled?0
It reboot also if i took over al the disks. I THINK i have it enable but i’m not sure. I try to reset by rear button but always reboot. Ho i can help you find cause of this continuous reboot? For now Many thanks0
It is a known (by me) problem on the NSA series that the timed shutdowns can 'go wild'. I'm not sure how it's caused. The box has a battery operated clock, so it should always know which time it is. But if the box 'goes wild', it will shutdown the box before the webinterface is up, and before the reset button is parsed.I can't remember I heard about this problem on a NAS series, but it won't hurt to try the same remedy.Download the universal usb_key_func stick here: http://zyxel.diskstation.eu/Users/Mijzelf/read the readme, and use the usb_key_func.sh.telnet_and_stop file. If that stops the cycle, and you are able to login over telnet, the box can be reset by a command line command. I'll have to search which one.
thanks a lot. i hope your readme file is complete, becouse i'm a ignorant with telnet and i never use it. but i never give up! i wait for the command line for reset and for now ever thanks!
Hey. clashed with the same problem. Reset does not help. The network address is not assigned. I'll try the method, unsubscribe.0
Meanwhile I have found that on the NAS5xx the 'telnet and stop' script has to be edited. Instead of
<div>telnetd -l /bin/sh</div><div></div>
it should betelnetd
The -l option is not supported. This means that you'll have to login, but at this level the password for root and admin is not yet set. I hope it's 1234BTW, the file has to have Linux line endings. For Windows you can use PsPad for that.0
- 397 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 5.1K Security
- 87 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 916 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 211 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2K FAQ
- 913 Nebula FAQ
- 421 Security FAQ
- 237 Switch FAQ
- 207 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 139 Service & License FAQ
- 72 About Community
- 62 Security Highlight
