Unable to access NAS 540 WebUI even after reset
rluch
I have been unable to login to my NAS 540 for a while (a full year at least).
When trying to access WebUI I am redirected to: http://10.0.0.5:5000/r50984,/desktop,/index.html
here I just see the gradient background, no login form elements.
In the inspector console, the following errors are thrown:
index.html:1 Uncaught SyntaxError: Unexpected token <
index.html:44 Uncaught ReferenceError: modeFlag is not defined
at index.html:44
I didn't manage to find any immediate solutions online, so I attempted first soft reset (one beep) followed by full reset (two beeps + 5 seconds).
The issue remains, but now I no longer have access to my shares nor SSH.
I later found this: https://homeforum.zyxel.com/discussion/564/nas326-stuck-spin-on-desktop which I fear was a simple solution.
Restarting the NAS and removing the disks has not helped.
I hope someone can help with a solution or approach. The only one I see right now, is manually backing up the data and resetting wiping the disks.
Thank you
#NAS_Dec_2018
#NAS_Dec_2018
You shouldn't be redirected. Have you already cleared your cache, tried another browser, etc?When I login on my 520 by entering http://nas520.lan, it takes me to http://nas520.lan/r50984,/desktop,/login.html, and I can login.When I manually enter http://nas520.lan:5000/r50984,/desktop,/login.html, I get the same login page, but after logging in it takes me to an empty page http://nas520.lan:5000/r50984,/desktop,/.
I feel very silly. I was sure I had tested in incognito, but accessing the IP (no port) in IE (which I rarely use) redirected me to the correct login page.
Thank you very much for the reply (and many others) as well as all your hard work Mijzelf!0
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 348 Security Ideas
- 53 Wireless Ideas
- 485 News and Release
