MySQL and MyPHPadmin not working together
Roger_Waldrip
I am unable to access my MyPHPadmin nor MySQL on my NAS540. I tried to use the reset password but MyPHPadmin still will not connect. Anybody have any ideas?
#NAS_Dec_2018
#NAS_Dec_2018
Do you mean that you can't see the MyPHPadmin page or you can see the page, but fail to login?
The latter you can go "/i-data/sysvol/.PKG/PHP-MySQL-phpMyAdmin/gui/phpmyadmin" via telnet/ssh and cat config.inc.php to check the login password.
But if it is the former, try disable and enable the package, and the worst case is to reinstall the package.0
- 588 USG FLEX H Series
- 477 News and Release
