Is there a way to encourage my Android phone to connect to the Multi X with the fasted WIFi signal
TonyC
I have just installed 2 Multi X devices. One upstairs and one down. I have given them both the same network name for 2.4 and 5ghz. My problem is that once my phone (Samsung S8+ latest Android version) has latched on to one it won't let go and latch on th the faster one as I move round the house. Is there a solution other than manual intervention?
#MultyX_Jan_2019
#MultyX_Jan_2019
As far as I know, when Multy X finds that the signal is better than 1st node after the client device is close to 2nd node, Multy X tells the client device to connect to 2nd node through 802.11kv. But roaming or not, it is depend on client device decision/design.
How do you know Samsung S8+ won't to switch the faster one node? Do you try to wait a while when you closer that node?
Maybe you can try to turn off and turn on WiFi of Samsung S8+.0
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
