NSA325: Trouble installing MetaRepository
I read/researched as many posts around the net about my issue but since many forums have been discontinued, I'm having issues finding answers. I'd like to get SMB updated to Version 2.0 or 3.0 and read that I should install MetaRepository for this on my NSA325 V1.
Firmware: 4.81
First, I copied MetaRepository_20181001_arm_015.zpkg into my \\nsa325\admin\zy-pkgs folder. Then went to web interface and click Retrieve List from Internet under Package tab. However, the factory list only shows. I never get the Meta install prompt
Next, I created a web_prefix file with the URL for the files but still no luck
I then read about getting root access. I was able to telnet with root & my admin password, lookup my NsaRescueAngel password (/sbin/makekey) and then going to http://<ip-of-nas>/r<entered my code>,/adv,/cgi-bin/remote_help-cgi?type=backdoor, then logging into NsaRescueAngel with that password. I then went back to the web interface and tried again. Still no luck.
What am I missing? Also, once I do get Meta installed what package should I install to get SMB updated?
Thanks guys,
Jon
#NAS_Jan_2019
Oops! Sorry, the name is zyxel-samba-replacement.
Here are installation instructions:To install samba 3.6.25 you have to install Entware-ng, and in Entware-ng zyxel-samba-replacement
Thanks Mijzelf!!! I guess my link was not correct in the web_prefix file from prior instructions. It installed now but when I go to the management page, it's blank and the page keeps on trying to refresh.
Update: Never mind. I tried Chrome and it worked flawlessly. Previously I was using IE.
Thanks so much for all you do.
Last hurdle... I think.
I got as far as installing entware-ng. I don't see zyxel-samba-replacement in the packages. All I see are in the screenshot attached when searching for samba
Should I just install the server package?
Thanks again.
The repo in the screenshot is the 'official' repo only.To get the zyxel-samba-replacement package, you should login over ssh/telnet (rad the 'Shell access' chapter).More here:
Another step closer but with a glitch. I followed the directions but got this error. I did an LS command but no files showed up. I also did a cd opt but it wouldn't allow me to change directories. I'm a newb. Thanks Mijzelf
No apologies you're doing me the favor. Thanks for everything and responding. Getting really close but got the last error.
That's a harmless one-time bug. On next start it's gone.0
Repped! Everything works great and now I don't have to enable the insecure SMB 1.0.
For those trying this too, go into Shares and for each one you setup, unclick the use Recycle Bin. You won't be able to access the shares on windows unless you remove that check box.1 -
Where and how can I add more repos (with the zyxel-samba-replacement)
I've already installed entware-ng. I don't find the package in the UI (like the screenshot above), but '# opkg list' prints: 'zyxel-samba-replacement - 3.6.25 - Replace the ancient samba server of a ZyXEL nas by the more modern Entware-ng one.'
As a pessimistic software dev ... how does the replacement work? From some comments I *think* it will stop the builtin smbd and starts the one from /opt
Will the web-UI to configure still work?
Any known issues (expect the recycler bin)?0
- 244 Nebula Ideas
- 6.9K Security
- 807 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 540 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
