Coil whine issue
Clowningman
Hello. I have a Synology NAS connected to a Zyxel switch (GS1200-5) through an ethernet cable. Whenever the NAS goes to sleep (disk goes to sleep), the switch begins to emit a high pitched "whining" noise, which I suspect to be coil whine. What can I do about this?
#Home_Switch_Jan_2019
how come....they just connected with one ethernet cable... what about remove the ethernet cable?I guess the noise was already there, but while NAS goes to sleep and quiet, then you hear the voice.0
... no.I just bought the switch and the noise began right then. It does not make that sound while the NAS is on. I guess I may have to return the product.0
If the noise began while you first time to plug the power, then you should swap a new one.0
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
