Is DHCP server turned off in bridge mode?
w8rn8r
w8rn8r Posts: 20 image  Freshman Member
First Comment Sixth Anniversary
edited January 2019 in Multy WiFi System
My network has two Multy X devices, first one in bridge mode, and a cable router from the provider with WiFi turned off and DHCP server active with a limited address range to be used and a few IP addresses reserved via MAC.
Every now and then, I'm seeing IP addresses on my network that are outside of that range.
Is there a DHCP server active when the first Multy X is in bridge mode?
#MultyX_Jan_2019
  • Zyxel_Steven
    Zyxel_Steven Posts: 246 image  Zyxel Employee
    Hi w8rn8r,
    If your Multy X as bridge mode, it hasn't DHCP server feature to serve main network of Multy X.
    Main network IP addresses will get from upper layer router.
  • Zyxel_Steven
    Hi w8rn8r,
  • w8rn8r
    Thanks, Steven; I was hoping that this would be the answer to my question.
    But then I'm still puzzled about what device could be assigning these "rogue" IP addresses ...
  • Dash
    Dash Posts: 65 image  Ally Member
    edited January 2019
    Can you screenshot the device IP information with "rogue" IP addresses?
    Or is there more description about "rogue" IP addresses?
    And what is your network topology and IP range of DHCP server?
