Internet speed tests missing
Labessane
I have noticed that the Test/Start option is missing from the broadband speed test window. Also, when I go into diagnostics and run the full test option, all of the internet facing tests measure 0/0, but the internal tests are fine. There seems no way to measure internet performance through Multy any more. I have 3 separate external setups and all have the same problem, but run different broadband services. I have tried rebooting my router and Multy at each location, but the problem persists. I can access the internet from all devices via LAN and Wifi and can run a broadband speed checker on my PC with the desired results. I am on the latest firmware and app releases. Has anyone noticed this problem?
#MultyX_Jan_2019
#MultyX_Jan_2019
3
I‘ve setup the MultyX System today and have the same Problems.
Same here.0
Same problem here, it has worked before.0
@Labessane, @Godzilla13, @Gagac, @Kristian,
Recently, Ookla (Speedtest) server has changed its protocol from http to https to cause Multy X cannot get server list. We are working to modify the configuration file of Speedtest and will release new firmware to fix this issue soon.
Update.
New firmware and new App has released to fix this issue.
Hey, just installed my Multy x system today the 30 januar and i also have the same problems,0
Since firmware update speed thro 3 multy’s is significantly lower - anyone know why? I’ll try restarting them0
Same problem here
Dear All,
This issue has already fixed on the latest firmware, please kindly upgrade your Multy X and Multy App.0
- 431 Beta Program
- 2.6K Nebula
- 164 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
