Can i run a vpn client on a nas540
Probably a stupid question, but I wan't to put the 540 behind a VPN.
Can i run a vpn client on the 540?
Do i need a firmware upgrade (still running original 5.04).
I know, its better to buy a new router with vpn but i'm curious if it's possible.
thx
#NAS_Jan_2019
Best Answers
If you know how to install other 3rd party VPN tool then you can try it, but officially, Zyxel's package doesn't have VPN client package so you can't install it, even upgrade.0
thx for your fast answer
i can work with the commandline (done it often for raspberry pi), but i'm surely not good enough finding a solution when something goes wrong :'( .
With the client config you mean: "Now the client side. Go back to /opt/share/openvpn/easy-rsa, and execute" ........?. I've seen this page before (the originale one) and thought that is was for the client on a different machine to connect to the nas540-server?
(i can't access page 2 in the archive anymore?).
If anything goes wrong, can i "redo" this, or "start" in original state?
Is it 'better' to 'put' debian on the 540 (https://l.unchti.me/2016/02/12/debian-nas540.html)?
No. The only difference between an openvpn server and client setup is in the config file. In server config the keyword 'server' is set (in the tutorial server-bridge), and in a client the keyword client.
The binary is identical. The client config file in the tutorial is suitable for connecting to the server from the tutorial. But your openvpn provider probably can provide you a suitable config for his server.
If anything goes wrong, can i "redo" this, or "start" in original state?Yes, in the startpost of the thread:There is no uninstaller. If you want to uninstall, just delete /i-data/sysvol/optware.After that, and a reboot you can start over.Is it 'better' to 'put' debian on the 540Debian has more possibilities, of course. But OpenVPN is OpenVPN, and the configuring on Debian won't be easier than on "Optware".(i can't access page 2 in the archive anymore?).Yes. Unfortunately the original forum is not accessible, at the moment, and archive.org didn't archive everything.
- 441 Beta Program
- 293 Service & License
