Multy X App not showing any connected devices on Parental Control
The_Marshal
The_Marshal Posts: 4 image  Freshman Member
edited February 2019 in Multy WiFi System
MultyX Firmware: V2.10(ABKJ.7)C0
Android Moto Z3 Play phone, App Version 2.2.3190130
I was on the previous Firmware 2 weeks ago, and on a different phone. And the Attached Devices (parental controls) stopped showing up.
They are still not showing up in the App after:
Upgrading to a new phone.
Upgrading to the Latest Firmware
Uninstalling and reinstalling App
I see on homepage I have 19 connected devices, and this will change as people use IP devices around the house. But I can no longer view them individually or work with them.
This is frustrating. I can not work with devices.
#MultyX_Feb_2019
  • Hanamichi
    Hanamichi Posts: 125 image  Ally Member
    What do you mean about your problem?
    Is there any screenshots?
  • Penny
    Penny Posts: 65 image  Ally Member
    The_Marshal,
    Does device list shows empty, but there are some client connected to MULTY X?
    Do you try to re-install MULTY APP or reset MULTY X?
  • ENDLESS
    ENDLESS Posts: 56 image  Ally Member
    Hi The_Marshal,
    I have the same problem before and completely reinstalled my Multy X, it has resolved. Do you try to reset and reinstall it?
  • The_Marshal
    When I look at the Device List it is a blank white screen. No devices listed
    Are y'all suggesting that I DELETE the existing network, and then reinstall both the App, and then install the MultyX as a new network?
  • The_Marshal
    I have reinstalled the phone app 2x. No change.
    I restarted the Nodes several times.
    I have not DELETED everything and started over.
  • ENDLESS
    Do you remember that you ever reserve some IP for specific device via Multy App?
    In this case, maybe you should try to reset and reinstall your Multy X to solve this problem.
