NAS540-NAS542 UPNP and IP block for Dservice (bittorent)
sim_v
sim_v Posts: 4 image  Freshman Member
edited February 2019 in Personal Cloud Storage
Hi;
UPNP configuration doesn't  allow to open default 9090&9089 ports for the included bittorrent client (by the way which one is it ?).
I notice too a lot of blocked connection : "Download service blocked peer: 160.178..." even without block list.
regards,
Simon
#NAS_Feb_2019
  • Ijnrsi
    Ijnrsi Posts: 254 image  Master Member
    is it block by router?
    to check listen port for NAS, try these command: "losf -i", "netstat -tulpn"
  • sim_v
    IP are blocked by the NAS. I just changed the NAT configuration on my router : TCP only for 9090 et UDP only for 9089.
  • Ijnrsi
    how about change use to transmission package?
    it is also the tool for bittorrent download.
  • sim_v
    I use my NAS away from LAN : included download service can be reach from admin console, I can transfert files with Files Browser and all is behind HTTPS and login/password.
    Transmission is better with LAN : no login !
