NAS520 keeps rebooting
MinoS
Hi everyone !
I've just bought used NAS520 and it seems to work fine previously. But I just can't get it work.
It just boots.. blinks different leds, start the hdd and then reboots.
I tried different HDD combinations (1 HDD, 2 HDD, no HDD), tried hdd freshly formatted to ext4 - no luck.
Tried to remove the battery - all the same.
Factory reset doesn't help...
Maybe I should flash the firmware from USB ? But I can't find a good manual for that.
Please advice.
#NAS_Mar_2019
Please advice.
#NAS_Mar_2019
reboot while you create volume?
The disk was created file system previously?0 -
I can't even get it working. So no Gui, no access through lan, no volume creation) Just reboot every15-20sec
And yes, I tried with ntfs and with empty ext4.0 -
Hi @MinoS ,Please check your private message in order to provide you the better service.Best Regards,Brian.0
@Zyxel_Brian thanks a lot ! I will try your instructions.
For anyone who curious - here is video of how it works now
https://youtu.be/RqsduWgjisU 0 -
So usb restore didn't worked. Seems like it start to restore and then reboots as usually.0
I have the exact same problem with my nas 520 now. It started yesterday. Can you tell me what you did to fix this issue? Assuming that you got your NAS fixed?
- 588 USG FLEX H Series
- 477 News and Release
