NAS326 - Where is the 1,2tb gone?
määck
I recently tried to extend one of my volumes, and the usage of disk group 1 was correctly put to 100%, but the 1,2tb never showed up in the volume. It's now just gone!
I attached a screenshot of said disk group. You can see that the volume is only 2,4tb while the disk group has a usage of 3,6tb. This is the only volume in this disk group.
Has someone a clue what is going on and how I can get my disk space back without deleting the whole volume?
#NAS_Mar_2019
#NAS_Mar_2019
It seems that the volume is bigger than the embedded filesystem. Did you interrupt the resizing procedure?Anyway, resizing the filesystem should be a breeze. Simply execute
su<br>resize2fs /dev/vg_5809fa3c/lv_94593aed
Can you login over ssh, and post the result of
<div>cat /proc/partitions</div><div><br></div><div>cat /proc/mdstat</div><div><br></div><div>su</div><div><br></div><div>vgscan<br></div><div>lvscan -a</div><div></div>
The first command will show all blockdevices (disks. partitions, raid arrays, ...) known to the kernel. The second will show all raid arrays, their status and members. The 3rd command will elevate you to root. (SuperUser), and the 4th will show all volume groups, and the 5th all logical volumes.0 -
Hey,
I put the commands into the ssh, here is the result:
Thanks for the help!0 -
Hm. That doesn't tell where your space is gone. You have 3 volumes, 3.63TiB, 1000GiB and 859GiB. These are located in different disks, and can't interfere.That 3.63TiB volume doesn't seem to be divided in 'sub-volumes'. So either the filesystem is smaller than the volume, or it's a (cosmetical) bug in the webinterface.The command
df /dev/vg_5809fa3c/lv_94593aed
can tell you about the size@free space of the filesystem on the 3.63TiB volume.0 -
Hey, I ran the new command, here is what it says:
I don't think it's just a bug in the interface, since Filezilla and the Finder also tell me the size of the volume in question is 2,4tb rather then 3,6tb0 -
Awesome, that worked! Thanks a lot for your help Mijzelf!0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
