Problem With my NSA325 v2
maxxalin2000
Hello, i have an old NAS model: NSA325 v2 with 2 HDDs (Seagate ST4000VN000-1H41) in RAID 1 and i have a strange problem with it.
Thanks!
PS: i have the latest firmware on NAS.
#NAS_Mar_2019
Everything worked perfectly until i reached 80% of the storage capacity (2.90 TB) Used of total 3.58 TB. If I try to copy something on it, it does not work, the NAS disconects from the network and if i refresh "status page' CPU is at 100% it stays like this for approx. 1 min and then everything returns to normal. I can not copy, unless I delete something and do not exceed 80% of the total storage. I tried to scan the volume and everything seems OK. I removed the HDDs and checked them separately for bad sectors but nothing found on them.
Does anyone know what might be the problem? Or have an idea about it?
Thanks!
#NAS_Mar_2019
I have read previous reports that a ZyXEL nas collapses when the volume is almost full, but I have never seen it myself, and so have been unable to investigate what is going on.And almost full is not really the case here, as you still have 500GB left. You can install the ssh package, login over ssh, and run 'top' to see which process is responsible for that 100% CPU usage.Further you can run 'dmesg' after a network disconnect (and reconnect, I suppose) to see if the kernel log contains a clue what is happening.1
- 3K Nebula
- 232 Nebula Ideas
- 6.7K Security
- 683 USG FLEX H Series
- 362 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 309 Service & License
- 504 News and Release
- 96 Security Advisories
- 5.1K FAQ
- 89 About Community
- 111 Security Highlight
