Hallo I'm italian. I have a LTE5366 only connected with a 4g sim my provider is Tim. I have this problem, sometime the modem lose connection, I need to reboot it. The firmware is V1.00(ABKA.0)C0 . I have a pocket router and I haven't problem with the same Sim. Have you any ad vice for me?
#LTE_Mar_2019
Lte 5366 problem
Boris34
Hi Boris34,
May I know if you have external antenna on your device? If no, can you please help to check the setting of antenna selection? To configure it to “internal” and then check if this issue is resolved or not.
I have eterna antennaantennas and I set the configurati on "external"0
Hi Boris34,
May I ask your help to configure it to “internal” antenna to check if it can be fixed or not?
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
