HO to add a virtual server in Mylty X ?
kyang0723
I would like to create a virtual server for my minecraft.
How can I add a virtual server in Mylty X
Thank you
#MultyX_Apr_2019
Thank you
#MultyX_Apr_2019
What kind of virtual server? Any information?
Can you share the purpose? What kind of application you want?
BTW, Multy App can set port forwarding, I think this is what you want.
https://homeforum.zyxel.com/discussion/1447/how-to-set-up-port-forwarding-via-multy-app#latest
Why Multy does not use some reserved or non-well-defined port to config or connect?
it is confused to setup a web server or something need SSH port behind the Multy.
release the public defined port for user is a good designed for ALL users.0 -
Hello Legis,
Can you share what kind of setting you want to configure?
You can use not reserve external port of Multy X to map internal port of your device.
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
