Any way to get to data on now-obsolete NSA310?
HappyChris
HappyChris Posts: 1 image  Freshman Member
edited April 2019 in Personal Cloud Storage
Recently my NSA310 has stopped responding, probably due to changes in Win 10 and MacOS SMB requirements. I have made some headway with setting the Win 10 network, changing from 'can't find it'  to being able to see SMB 1 - where there was no connection at all before, there is now access to the login screen but just a black screen (sometimes with 'thinking about it' icon, sometimes not.
I tried removing the HDD and inserting it in an USB drive case but it couldn't read it at all. Might this be the NSA's file system? I would be surprised if the disk is encrypted.  Maybe if I swapped the disk to a case and plugged it into a Linux machine?
Anyway, is there anything that I and others can do to make this device work again with MacOS andor Windows, please?
#NAS_Apr_2019
  • Rory
    Rory Posts: 120 image  Ally Member
  • Mijzelf
    Mijzelf Posts: 3,042 image  Guru Member
    The 310 originally used the XFS filesystem (as you can see here). It is possible that later firmwares used ext3, when setting up a volume. For ext3 Windows drivers are available, but the filesystem is inside a software raid container, which make it hard to access. But any Linux box should have no problems with it.
