LTE3302 Brindge Mode Disconnections
Paladium
Hi
i have a Unifi Setup with a Cableconnection at WAN1 and for the Backup a LTE3302 with unlimited Data on WAN2.
The setting works fine in Normal Mode.(Not Bridged)
I can disconnect WAN1 and the Unifi Router make a failover to WAN2.
But for Rechable Reason i need to Bridge the LTE3302.
After Bridging the LTE3302 he try to connect and after a second he disconnect and try it again.
What could be wrong?
Thank you for your Help.
Paladium
#SP_Apr_2019
Paladium
#SP_Apr_2019
Hi Paladium,
Do you mean that after switching to bridge mode on the LTE3302, the LTE3302 tries to connect to the LTE network but never really successfully connects?
Does the “Status” page show a WAN IP address, as the following image shows?
Also, could you please take a screenshot of the LTE Modem Status page (web GUI > Monitor > LTE Modem Status)?
Thank you.
Hi YeKKu,
No, he connect to the LTE but then he fail to build a stable connection from LAN LTE3302 <> Unifi USG.
Thats Bridged with a Ping over WAN1:
Thats Bridged with a Ping over WAN2 after Disconnect WAN1 on Unifi Router:
And the Settings from LTE3302:
(I lose after activate Bridge Mode the connection to the LTE3302.)
And the WAN Settings from LTE3302:
Regards
Paladium0 -
Problem Solved:
Solution:
Have disabled Firewall and IPV6 on WAN.
Now works Fine on Main and Backup.
- 441 Beta Program
- 293 Service & License
