Second node not turning to blue led for setup
Alexhdz321
Alexhdz321 Posts: 2 image  Freshman Member
edited May 2019 in Multy WiFi System
Hello team I recently purchased the Multy U system and I am having issues with the secondary node. It is staying in a solid white LED and will not change to blue. I attempted to reset using the button on the back multiple times with no changes. Any suggestions on how to resolve this issue?
#MultyU_May_2019
  • Teemo
    Teemo Posts: 55 image  Ally Member
    edited May 2019
    When you press the reset button for at least 5 seconds, do the LED starts to blink amber or anything happen on LED? Does the LED always solid white? Do you not able to add 2nd node?
  • Dash
    Dash Posts: 65 image  Ally Member
    Hi Alexhdz321,
    Has the secondary node been install before? As you said: it is staying in a solid white LED, how long you're waiting for LED status? Always is solid white and not change to blue?
    You can try to hold reset button of Multy U, and then power on Multy U, when the LED turns to green, please release reset button. After that, please power off and power on Multy U to check its LED can turn to blue and ready for installation.
  • Alexhdz321
    Hello team, I ended up replacing the node after trying the steps above.
