NAS542 bootloop after Debian/OMV (get a new firmware) (solved)
Unfortunately this gives me: "No such file or directory".Then i tried: "mount ramfs /mnt"But that shows me the Usage text again. "Usage: mount [<device> <fstype> <mountpoint>]"
Bummer. I assume the /mnt directory exists?According to the barebox site barebox can also mount fat filesystems. Does a disk showup in /dev when you boot the box with a disk and/or usb stick inserted? And can it be mounted?0
O M G . I really forgot that. (Too much testing with reboot every 30sec and a hairdryer next to me.) Now something is right, cause i get no error. Instead i get only a new prompt line. Then i tftp into the /mnt folder. After that i used "bootm /mnt/uImage.521", this gets me the same ERROR: Out of memory.With USB, i formated a stick with fat32, plugged it in but i don't know how to find it. Dmesg and lsusb doesn't work on barebox. Couldn't find him in /env nor in /dev. I found something about automount here: https://www.barebox.org/doc/latest/user/automount.htmlMy system tells me "unknown command 'automount'Seems this barebox.org/doc is outdated, or can barebox be adjusted? I mean could Zyxel make an own barebox with only the most necessary stuff they want?
Again? Does 'mount' show the ramfs is actually mounted? Does the 'meminfo' command show the available and used memory? Is the ramfs subtracted from the main memory?
And does another uImage (for instance that Debian one) boot?
can barebox be adjusted?AFAIK yes. The manual tells you can configure it with 'make menuconfig'. Which is also the way you can enable or disable applets in the Linux kernel or busybox.
With USB, i formated a stick with fat32, plugged it in but i don't know how to find it.How about the usb command?
The usb command doesn't work here (unkown command). I also couldn't find anything related to USB in the Command-List. Also meminfo doesn't work. I found the command "md" but it shows me:Barebox-C2K >/ md
00000000: ffffffff ffffffff ffffffff ffffffff ................
00000010: ffffffff ffffffff ffffffff ffffffff ................
00000020: ffffffff ffffffff ffffffff ffffffff ................
00000030: ffffffff ffffffff ffffffff ffffffff ................
00000040: ffffffff ffffffff ffffffff ffffffff ................
00000050: ffffffff ffffffff ffffffff ffffffff ................
00000060: ffffffff dfffffff ffffffff ffffffff ................
00000070: ffffffff ffffffff ffffffff ffffffff ................
00000080: ffffffff ffffffff ffffffff ffffffff ................
00000090: ffffffff ffffffff ffffffff ffffffff ................
000000a0: ffffffff ffffffff ffffffff ffffffff ................
000000b0: ffffffff ffffffff ffffffff ffffffff ................
000000c0: ffffffff ffffffff ffffffff ffffffff ................
000000d0: ffffffff ffffffff ffffffff ffffffff ................
000000e0: ffffffff ffffffff ffffffff ffffffff ................
000000f0: ffffffff ffffffff ffffffff ffffffff ................It does not change after mount a ramfs.
With the output of devinfo i can see the new ramfs1 at the end of devices which wasn't there before.
Barebox-C2K >/ devinfoAlso the mount command tells it is there: (before&after)
devices:
|----ramfs0
|----devfs0
|----mem0 (defaultenv)
|----mem1 (mem)
|----fast_uart0
|----cs0
|----c2k_i2c0
|----eeprom0
|----c2k_spi0
|----S25FL064A0
|----comcerto_spi10
|----comcerto_spi20
|----legerity0
|----c2k_otp0
|----c2000_eth0
|----miidev0 (phy0)
|----eth0
|----c2000_eth1
|----eth1
|----cfi_flash0
|----csi_flash0 (spi0, env0, spi0.uloader, spi0.barebox, spi0.env)
|----comcerto_nand0
|----nand0 (nand0, nand_oob0, self_raw, nand0.config, nand0.kernel1, nand0.rootfs1, nand0.kernel2, nand0.rootfs2, nand0.reserved)
|----ramfs1
drivers:
fast_uart
ramfs
devfs
miidev
c2000_eth
comcerto_nand
cfi_flash
c2k_spi
c2k_fast_spi
csi_flash
c2k_i2c
c2k_otp
mem
cramfsBarebox-C2K >/ mount
none on / type ramfs
none on /dev type devfs
Barebox-C2K >/ mk mnt
Barebox-C2K >/ mount none ramfs /mnt
none on /mnt type ramfsSeems i do not have to make a ramfs cause "/" is already one.
I tried "mtest" but that tells me: "Usage: <start> <end>". But nothing worked: "mtest -start", "mtest start", "mtest 1", "mtest <start>" , "mtest".
Then i copied a Debian uImage without "mount" and "/mnt" only with "tftp uImage1". After "bootm uImage1" it started booting, but ends up in a "Kernel panic error". Attached is the boot-log.
At the beginning of the boot-log: "Memory: 44MB 960MB = 1004MB total" "Memory: 1012108k/1012108k available, 36468k reserved, 0K highmem". There should be enough memory, i think.
Thank you for your help. Hope this NAS will work again.
So de Debian kernel works, and the ZyXEL kernel gives an 'Out of memory'. I think the ZyXEL kernel is actually way bigger, as it includes the initramfs, and the Debian kernel doesn't. By writing a file to a ramdisk it's not known (to me) where it's located. When booting a uImage the payload has to be written to a physical address, 0x8000. If there is not enough room until the first barebox components, that could give an 'Out of memory'Output of"addpart /dev/ram0 8M@0x8000(kernelraw)" => "No such file or directory"/dev/ files:zero, defaultenv, mem, phy0, spi0, env0, nand0, nand_oob0, self_raw, self0, spi0.uloader, spi0.barebox, spi0.env, nand0.config, nand0.kernel1, nand0.rootfs1, nand0.kernel2, nand0.rootfs2, nand0.reserved, nand0.reserved.bb, nand0.rootfs2.bb, nand0.config.bb, nand0.rootfs1.bb, nand0.kernel1.bb, nand0.config.bbThere is no ram0 in /dev. But there is a mem. I dunped the barebox partition in my 520, and run strings on it, and found it contains lots of scripts. In one of them I found this snippet:
elif [ x$kernel_loc = xsata ]; then<br> addpart /dev/mem 3M@0x3008000(uImage)<br> sata read 3008000 1 5000<br> kdev="/dev/mem.uImage"<br> sata stop<br>
So apparently it's also possible to use /dev/mem, and mem is available. (And I have no idea what the difference is between mem and ram0). When creating this partition(?) the physical address and size if given. So I suggest to repeat that commands with /dev/mem instead of /dev/ram0
I tried this with both, the Debian/OMV uImage (uImage1) and with your uImage.521. Both outputs are attached. The uImage1 is the same as before, Kernel panic. The uImage.521 is doing more, tried this 2 times, both the same. Something with NAND Flash corrupt and ubiattach seems to me making this problems.(search for: "ubiattach: error!: cannot attach mtd7")0
Looks good. Did you get this using /dev/mem?
mtd7 is rootfs2cat /proc/mtd<br>dev: size erasesize name<br>mtd0: 00040000 00010000 "uloader"<br>mtd1: 00080000 00010000 "barebox"<br>mtd2: 00040000 00010000 "env"<br>mtd3: 00a00000 00020000 "config"<br>mtd4: 00a00000 00020000 "kernel1"<br>mtd5: 06e00000 00020000 "rootfs1"<br>mtd6: 00a00000 00020000 "kernel2"<br>mtd7: 06e00000 00020000 "rootfs2"<br>mtd8: 00600000 00020000 "reserved"<br>mtd9: 06406000 0001f000 "ubi_rootfs1"<br>mtd10: 0045c000 0001f000 "ubi_config"
So if kernel2 was never filled, rootfs2 isn't either.
In your bootlog I see traces of the script /etc/init.d/rcS. This script contains the next snippet:# which kernel and system image partitions<br>CURR_BOOTFROM_UPDATED="0"<br>NEXT_BOOTFROM=`${INFO_PRINTENV} next_bootfrom | awk -F"=" '{print $2}'`<br>CURR_BOOTFROM=`${INFO_PRINTENV} curr_bootfrom | awk -F"=" '{print $2}'`<br>if [ "${NEXT_BOOTFROM}" != "${CURR_BOOTFROM}" ]; then<br> CURR_BOOTFROM="${NEXT_BOOTFROM}"<br># ${INFO_SETENV} curr_bootfrom "${CURR_BOOTFROM}"<br> CURR_BOOTFROM_UPDATED="1"<br>fi<br>#CURR_BOOTFROM=`${INFO_PRINTENV} curr_bootfrom | awk -F"=" '{print $2}'`<br>if [ "${CURR_BOOTFROM}" = "1" ]; then<br> IMG_MTD=5<br>else<br> IMG_MTD=7<br>fi
So if you exchanges the values of next_bootfrom and curr_bootfrom in the barebox environment, and boot the uImage.521 kernel, I'd expect an even better result.
I have done everything (copy file to local) except bootm and then tried "cat /dev/mem" but this filled the whole screen with unreadable content and doesn*t stop. Or did i understand something wrong?Under /env there is a config file and a bin folder. The config file:#!/bin/sh
# use 'dhcp' to do dhcp in barebox and in kernel
# use 'none' if you want to skip kernel ip autoconfiguration
ip=dhcp
# or set your networking parameters here
#eth0.ipaddr=192.168.2.22
#eth0.netmask=255.255.255.0
eth0.serverip=192.168.1.70
#eth0.gateway=192.168.2.1
#eth0.ethaddr=00:0A:0B:0C:0D:0E
#eth1.ethaddr=00:1A:1B:1C:1D:1E
#eth2.ethaddr=00:2A:2B:2C:2D:2E
# can be either 'nfs', 'tftp' , 'nor' , 'nand' and 'sata'
kernel_loc=nand
#kernel_loc=nor
#kernel_loc=sata
# can be either 'net', 'nor' ,'initrd' , 'nand' and 'sata'
rootfs_loc=nand
#rootfs_loc=nor
#rootfs_loc=sata
# barebox imagesIn the bin folder is this:
update update_rootfs _update update_uloader b0 hush_hack _update_help init update_barebox b2 b1 boot update_kernelin the boot file:#!/bin/sh
. /env/config
if [ x$1 = xnand ]; then
rootfs_loc=nand
kernel_loc=nand
#elif [ x$1 = xnor ]; then
# rootfs_loc=nor
# kernel_loc=nor
#elif [ x$1 = xsata ]; then
# rootfs_loc=sata
# kernel_loc=sata
#elif [ x$1 = xnfs ]; then
# rootfs_loc=net
# kernel_loc=nfs
elif [ x$1 = xtftp ]; then
rootfs_loc=net
kernel_loc=tftp
fi
if [ x$ip = xdhcp ]; then
bootargs="$bootargs ip=dhcp"
elif [ x$ip = xnone ]; then
bootargs="$bootargs ip=none"in the init file:#!/bin/sh
PATH=/env/bin
export PATH
. /env/config
#if [ -e /dev/nor0 -a -n "$nor_parts" ]; then
# addpart /dev/nor0 $nor_parts
#fi
#if [ -e /dev/disk0 -a -n "$disk_parts" ]; then
# addpart /dev/disk0 $disk_parts
#fi
if [ -e /dev/spi0 -a -n "$spi_parts" ]; then
addpart /dev/spi0 $spi_parts
fi
if [ -e /dev/nand0 -a -n "$nand_parts" ]; then
addpart /dev/nand0 $nand_parts
# Uh, oh, hush first expands wildcards and then starts executing
# commands. What a bug!
source /env/bin/hush_hack
fiupdate file:#!/bin/sh
if [ x$mode = xddr ]; then
if [ -z "$part" -o -z "$address" -o -z "$size" ]; then
echo "define \$part, \$address and \$size"
exit 1
fi
else
if [ -z "$part" -o -z "$image" ]; then
echo "define \$part and \$image"
exit 1
fi
fi
if [ ! -e "$part" ]; then
echo "Partition $part does not exist"
exit 1
fi
if [ x$mode = xtftp ]; then
dhcp
fi
ping $eth0.serveripupdate rootfs#!/bin/sh
. /env/bin/update -t rootfs -d $1_update:#!/bin/sh
exit 1
fi
else
exit 1
fi
fi
exit 1
fi
dhcp
fi
ping $eth0.serveripupdate_uloader:#!/bin/sh
. /env/bin/update -t uloader -d $1b0:#!/bin/shhush_hack:
. /env/config
rootfs_loc=nand
kernel_loc=nand
# rootfs_loc=nor
# kernel_loc=nor
# rootfs_loc=sata
# kernel_loc=sata
# rootfs_loc=net
# kernel_loc=nfs
rootfs_loc=net
kernel_loc=tftp
fi
bootargs="$bootargs ip=none"nand -a /dev/nand0.*_update_help:#!/bin/sh
echo "usage: update -t <kernel|rootfs|barebox|bareboxenv> -d <nor|nand> [-m tftp
echo "update tools."
echo ""
echo "options"
echo " -c to check the crc32 for the image and flashed one"
echo ""
echo "default mode is tftp"
echo "type update -t uloader -d <nor|nand> [-m tftp|xmodem|ddr] [-f imagename|-a
echo "type update -t barebox -d <nor|nand> [-m tftp|xmodem|ddr] [-f imagename|-a
echo "type update -t kernel -d <nor|nand> [-m tftp|xmodem|ddr] [-f imagename|-a
echo "type update -t rootfs -d <nor|nand> [-m tftp|xmodem|ddr] [-f imagename|-a
echo "type update -t bareboxenv -d <nor|nand> [-m tftp|xmodem|ddr] [-f imagenameupdate_barebox:#!/bin/sh
. /env/bin/update -t barebox -d $1b2:#!/bin/sh
. /env/config
next_bootfrom="2"
rootfs_loc=nand
kernel_loc=nand
# rootfs_loc=nor
# kernel_loc=nor
# rootfs_loc=sata
# kernel_loc=sata
# rootfs_loc=net
# kernel_loc=nfs
rootfs_loc=net
kernel_loc=tftp
fi
elif [ x$ip = xnone ]; thenb1:#!/bin/sh
. /env/config
next_bootfrom="1"
rootfs_loc=nand
kernel_loc=nand
# rootfs_loc=nor
# kernel_loc=nor
# rootfs_loc=sata
# kernel_loc=sata
# rootfs_loc=net
# kernel_loc=nfs
rootfs_loc=net
kernel_loc=tftp
fi
elif [ x$ip = xnone ]; thenupdate_kernel:#!/bin/sh
. /env/bin/update -t kernel -d $1I couldn't find anything which could switch the kernel (something with IMG_MTD=5). I only found the settings for the image in b1 and b2, but no matter what will be choosen, they point to the same place, hmmm.
I think so. If you run printenv, it should show something like
<p>...<br></p><p>next_bootfrom = 1</p><p><br></p><p>curr_bootfrom = 2<br></p>...
Then run setenv:<div>setenv next_bootfrom 2</div><div><br></div><div>setenv curr_bootfrom 1</div><div><br></div><div>saveenv</div>
and load@boot uImage.5210
- 435 Beta Program
- 183 Nebula Ideas
- 120 Nebula Status and Incidents
- 6.2K Security
- 440 USG FLEX H Series
- 299 Security Ideas
- 80 Switch Ideas
- 276 Service & License
- 433 News and Release
- 84 About Community
- 91 Security Highlight
