Aurora - Message no recording files in the selected period
pancho35m
Posts: 72 Ally Member
Hi Team,
Before i did the Firmware Update to V1.00(ABEQ3.3)C0 the aurora works fine. i got the notification that there was a detection and i could watch the recording. After the update i only get the notification i can also the notification on the app but when i want to see the recoprding i got this message.
No recording Files in the selected period.
So what is the solution on this case?
Thanks for your help
BR
Pancho
#Others_May_2019
BR
Pancho
#Others_May_2019
Hi pancho35m,
My Aurora firmware is the same with yours as V1.00(ABEQ.3)C0, but it works properly in my side.
Please make sure "Recording" is enabled. If it's still not working, you can tap "Clear" to format Storage, and then try it again.
Hi Penny,
thanks for your help
yes i clear the storage and recording was on
So like it is in your screenshot but no changes0 -
OKAY, it's strange. Did you try to reset and reinstall your Aurora?
- 347 Beta Program
- 2.1K Nebula
- 114 Nebula Ideas
- 77 Nebula Status and Incidents
- 5K Security
- 44 USG FLEX H Series
- 246 Security Ideas
- 1.2K Switch
- 64 Switch Ideas
- 901 WirelessLAN
- 33 WLAN Ideas
- 5.8K Consumer Product
- 204 Service & License
- 326 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.8K FAQ
- 831 Nebula FAQ
- 401 Security FAQ
- 219 Switch FAQ
- 190 WirelessLAN FAQ
- 45 Consumer Product FAQ
- 136 Service & License FAQ
- 71 About Community
- 61 Security Highlight
